Rib vs Ribless
skierp20
Springfield, MA
What is the difference between a Rib programming cable and a Ribless?? I understand that the Ribless is without the Rib Box, but what does that box do exactly?
Thanks!
bezking
On the Road
A Ribless cable isn't really ribless, the rib is just built into the cable. Basically, the RIB acts as a translator, turning data from the radio or computer into data the other one can understand.
HTH
skierp20
Springfield, MA
Is there an advantage/disadvantage to one vs the other? I know there are A LOT of people here that are more experienced at programming than myself. What do you prefer?
b7spectra
EMS Dispatcher
Cobb County, GA
The good thing about RIBless cables is that you do not need a power supply for it. It derives it's power from the computer. More and more of the cables are going that way - even old model Maxtracs, Radius's & GM300's! I can't wait to get one for both the Saber and Spectra!
grinthock
Toronto
Ribless cables basically have a rib built into the cable (as the other poster said)
the only problem is, there have been some ribless cables out there that were of questionable quality as the components they use for the protocol conversion are not exactly the same as the Motorola orig.
Also, the power it gets is from the computer - so this is a variable, I have one machine here that ribless cables don't work on - the power from the port isn't stable enough.
There are many variables in the "ribless" world, and the bottom line is a REAL rib is hard to beat because they work so well.
Many newer radios are only available with ribless style cables (XTS 2500/5000)
I find the newer radios are less picky than the other ones when it comes to voltages and timings so you will have better luck.
