Ribless programming driver USB cable
Mr_Boh
The Land of Pleasant Living
Which one? ribless cables still typically have a DB9 port to go direct to serial on a computer, so I assume you got it from someone has made one with an FTDI chip or Prolific chip to allow you to go direct to serial. You would just need the USB driver for the Serial to USB chipset because the computer needs to see it as a serial port.
jaspence
Michigan
I use the same setup for several of my older radios. I have not had to install any drivers using the kawamall cables.
