fire dept is use a new tac ch now it is 155.620 pl 107.2
leogetz92 Member Joined Mar 14, 2005 Messages 2 Feb 9, 2008 #1 fire dept is use a new tac ch now it is 155.620 pl 107.2
CVPI4Ever Member Joined Nov 7, 2004 Messages 844 Location Ohio Feb 9, 2008 #2 is that for the entire county?
leogetz92 Member Joined Mar 14, 2005 Messages 2 Feb 10, 2008 #3 They are used it off and on in the country they are still use 154.250 for tone the fire dept out
FPO703 Member Joined Jan 19, 2001 Messages 2,630 Location Planet Earth Feb 10, 2008 #4 155.620 is not a valid frequency. Might it be a NFM channel? Are they licensed to use it?
K kd8bor Member Joined Sep 22, 2007 Messages 7 Location Shelby, OH Feb 3, 2010 #5 Richland County TAC Channels I had recently gotten a hold of the Tac1, Tac2 and Tac3 frequencies that Richland County Fire uses. Tac1: 158.7375 Tac2: 156.0225 Tac3: 158.8725 Does anyone else listen to these? And if so, what scanner do you have? Brandon KD8BOR
K kd8bor Member Joined Sep 22, 2007 Messages 7 Location Shelby, OH Feb 3, 2010 #6 I was recently given the Tac channel from a member of a local fire department: Tac1 158.7375 Tac2 156.0225 Tac3 158.8725 I'm an unfamiliar with the 155.620 frequency.
I ibagli Member Joined Dec 2, 2006 Messages 983 Location Ohio Feb 3, 2010 #7 Those are all listed as repeater inputs right now. Are they also used with a different tone as simplex channels?
K kd8bor Member Joined Sep 22, 2007 Messages 7 Location Shelby, OH Feb 3, 2010 #8 I'm not sure. I'm trying to validate these frequencies.
O owenbricker Member Joined Feb 4, 2010 Messages 104 Location Mansfield Ohio Feb 4, 2010 #9 hi, the repeater outputs are, tac-1 155.0625, tac-2 155.6175, tac-3 154.9725, and unused so far 154.7025. these are narrow fm. tac-1 north, tac-2 central, tac-3 south. will post if the other freq becomes active. barry
