Not to mention that with some systems, the only way to crack in is to get help from the manufacturer of the type of system used. Once you determine the type, flavor, and "guts" of a network, then you start with serious working on it. That takes time itself, if its not a simple say Motorola Type I, II, IIi, EDACS, or LTR... SS.FH systems are very hard to break, as are systems using the newer encryptions, and digital formats other than the ones that are in everyday use here in the states. Lets say you set up a wide area TRS piggybacking on the areas AM/FM, Cellular, and Television towers, using say TETRA.... Or one of the military formats from say Cuba.... Heck your a drug cartel, you can afford anything out there..... It will take minimum a month for local LEA's to even begin to figure out what your doing, another month or so for them to finally go crawling to an higher level agency because even in this age of interop... Agencies don't like to ask for help unless its a top priority case. Then itll take about a month for them to get really working on it... So your safe if your using a good set up for at least 6 months. Thats a LONG time frame to do things, and set up a backup for that system. Not to mention, cartels don't have to worry about bidders, time frames, as cash buys you speedy work, legality of whose tower your on, again cash talks. Eventually yes, you'll get popped... on that net... But what about the other three nets you have established?? WEG
