Riscon trunking
sylg
Cranston, RI
RISCON (RI STATE WIDE COMMS) database lists channels, control channels, and alternate control channels.
Which of these has the audio I wish to hear?
I am using ARC-500 software for my GRE PSR-600. Which prorocol should I use?
Thanks so much!
sylg
04Z1V6
Castle Rock, Co.
Looks like it is P25 Use the Control channels for the towers in your area as small as it is you may just program them all, after you have done that then select the Talk groups you would like to listen to, then import them to the radio. The software will do the work for you, just check mark what you would like to listen to.
If I am wrong please someone jump in and help. This is better posted on the state forum because they are better aware of what is going on in your area. Post what County, city, and police, fire, public works, or Ham.
