RM KL 203 P AMP Frequencies?
FiveFilter
I just saw the instruction papers that came with a new RM KL 203 P amplifier which indicates the unit operates for frequencies from 10 - 22 MHz.
However, I've seen reports of this amp being good for 18 - 30 MHz, and some folks using it for CB work.
Anybody know why the discrepancy?
TheSpaceMann
I believe some manufacturers may not state the true range just so they can get around the FCC regulations.
FiveFilter
SpaceMann, that's what I figured: the manufacturer is making sure the world knows that it is not encouraging the illegal use of its device. Indeed, the instructions specifically say several times that the amp is not to be used in an illegal manner.
However, I found it unusual they would go as far as to specify a diminished capacity for the machine in a quest to prevent illicit usage. Doing so would be discouraging valid uses for it. E.G., if a person wants to use it for amateur frequencies above 22 MHz, i.e. 10 meters, etc., the instructions are saying the amp doesn't have the capability to accommodate it.
TheSpaceMann
Good point, but it does allow them to get into the US market. The CBers find out the true specs soon enough, and spread that info all over the internet! Remember, there are more CB customers for these units than hams, and hams have a large selection of other amps to choose from. The end result is that the manufacturer still makes a huge amount of money!
