Roanoke Airport & BCD396T
Salem, VA USA
Does anyone have a good suggested layout for System/Groups of roanoke airport to program into a BCD396T? I'm having a little trouble coming up with the appropriate layouts. I found the following info:
Airport Communications
UNICOM: 122.95
ATIS: 134.95
WX ASOS: PHONE 540-265-0680
ROANOKE GROUND: 121.9 257.8
ROANOKE TOWER: 118.3 257.8
ROANOKE APPROACH: 118.15 RY 15/33 (360-150) RY 06 (235 126.9 RY 15/33 (151-359) RY 06 (075- 339.8 RY 15/33 RY 06
ROANOKE DEPARTURE: 118.15 RY 15/33 (360-150) RY 06 (235 126.9 RY 15/33 (151-359) RY 06 (075- 339.8 RY 15/33 RY 06
CLEARANCE DELIVERY: 119.7
CLASS C: 118.15 RY 15/33 (360-150) RY 06 (235
CLASS C IC: 126.9 RY 15/33 (151-359) RY 06 (075- 339.8 RY 15/33 RY 06
EMERG: 121.5 243.0
As I'm very new to scanning, I'm having a little trouble getting it all organized. For example, I see Ground and Tower both two frequences, one of which is common. And the whole mess of Approach and Departure..
Any guidance offered would be greatly appreciated. Thank you
cpohlad
Midlothian, VA
The second frequency is the UHF frequency, for Mil Air. I just programmed all the VHF frequencies that you listed into the same group. There is not so much traffic at KROA that you can't keep up.
cpohlad
Midlothian, VA
Also, to add... In the evening (not sure the time) you will hear the same person handling multiple positions (TWR, APP/DEP, etc.)
richrowl
Chesterfield Co Virginia
The Roanoke Airport
I have not tried these for a couple of years, however, they should still be good.
Roanoke Airport Airspace
134.9500 ATIS
119.7000 Clearance Delivery
121.9000 Ground
118.3000 Tower
126.9000 Approach and Departure
118.1500 Approach and Departure
135.0000 Approach West of Lynchburg Vortac
125.4750 Approach East of Lynchburg Vortac
122.1000 FAA Flight Service Station
122.2000 FAA Flight Service Station
122.6000 FAA Flight Service Station
121.5000 Emergency and Disaster
257.8000 Military Tower and Ground
339.8000 Military Approach and Departure
254.3250 Military Approach east and west of Lynchburg Vortac
255.4000 Military Flight Service Station
243.0000 Military Emergency
FAA Washington Center Airspace (This is airspace not controlled by Roanoke)
127.9250 Valley Sector, Low Altitude
133.5740 Shenandoah Sector, Super High Altitude
134.6250 Tech Sector, High Altitude
317.7000 Military, Valley Sector, Low Altitude
270.3500 Military, Shenandoah Sector, Super High Altitude
377.2000 Military, Tech Sector, High Altitude
255.4000 Military Flight Service Stations
Landmark Aviation FBO
122.9500 UNICOM
130.5750 Air Operations
465.6750 [100.0] Ground Operations, Fuel Trucks
Passenger Airlines Air Operations
129.150 US Air Maintenance
129.800 US Air Ops
130.750 United Ops
131.025 Delta Ops
131.750 Northwest Ops
Passenger Airlines Ground Operations
460.6500 [141.3] United
460.6750 [156.7] Northwest
460.8000 [d265] US Air
460.8750 [d606] Delta
Cargo Airlines Air Operations
128.850 Airborne Express Ops, “ABEX”
129.425 United Parcel Service Ops, “UPS”
131.625 DHL Ops, “ABEX”
131.925 Federal Express Ops, “FEDEX”
Cargo Airlines Ground Operations
452.7875 [d612] UPS Terminal
452.8875 [d612] UPS Terminal
462.4875 [d612] UPS Terminal
462.5125 [d612] UPS Cargo Ramp
461.1125 [114.8] FedEx Cargo Ramp
Talkgroups (Roanoke 800 MHz Trunked Radio System)
65104 Airport 1, Ops, Security, Dispatch
65072 Airport 2, Maintenance
65040 Airport 3, Administration
Anyone finding changes or updates please post them here to keep the list accurate.
gcgrotz
Savannah, GA
Hey bbPhoenix, welcome to RR and the VA forum. Lots of good info gets passed here.
The common UHF freq for tower and ground is because of the relative lack of use of UHF. They have the same thing here at CHO. In fact, most of the time here, which I realize is even smaller than Roanoke, the VHF tower and ground channels are tied together and run by the same controller. The planes will come up on Ground when getting clearance and stuff but you hear the controller on both Ground and Tower.
Air traffic listening is a blast, there is always stuff going on even if it is routine. Check out www.airnav.com and www.flightaware.com for more info and flight tracking. I enjoy hearing a plane and then looking up where it is going, like the Gulfstream that left here one time going to the French Rivera with some lucky folks on board.
Also, if nobody has mentioned it yet, you should look into the ARC396 software from BuTel, it is pretty much indispensable. It will make it very easy to load the Roanoke public safety trunk system. I have a bunch of files for this area and some for Richmond for the 396. If you're coming this way you're welcome to ask for them.
kjnester77
Buchanan,Va.
Good to see some people close by.I live in buchanan if you know where that is.Botetourt County.Ive been trying to listen to RoCO/City trunking and have yet to hear anything.I can hear dispatch on the 48 band and thats about it.I have 7 banks programmed and never hear a thing.I`ve uploading the things directly from hear with the cable and still nothing.Roanoke is only like 20 minutes away.I would think i wouldn`t have much of a problem hearing anything from there.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
On a duckie or using an external antenna? With an urban landscape and terrain, a duckie - which is a loss antenna to begin with - isn't going to hear that much. More specifics are needed.
73s Mike
kjnester77
Buchanan,Va.
Just a stock antenna is all i am using.Its not a duckie.I had an external antenna that i bought at radio shack.It was one of those window antennas and the sticky came off i guess and it fell of my window and the mower got it.
gcgrotz
Savannah, GA
If you live in Buchanan, Roanoke is a tough shot. I remember trying to make a link on 959 Mhz work between Poor Mtn and Purgatory Mtn and it was marginal even from the peak. Somebody else up there used to have a 72 MHz link from Purgatory to Tinker Mtn and it worked OK. Too many big hills in the way.
Can you hear them if you drive down? At least you'll know your scanner is programmed properly.
kjnester77
Buchanan,Va.
I havent tried that.I am a volunteer FF,so in my reasoning is,when in roanoke my pager and radio work fine,but maybe thats different.I was up a friends today at he lives a bit closer to roanoke than i do,but i still never heard anything.Ill try driving up that way one day and see what happens.
pogbobo
VA
another frequency to add to that list is
121.7 Clearance Delivery Link in Dublin, VA
I'm in Radford and can hear it sometimes ... also, on a good day in my truck I can pick up the Roanoke trunked system, but its weak and choppy, not worth it until I hit the interstate ...
