thunderbritches174 said:
I'm using all the freqs for robins afb that are found in rr
As previously stated, only the red and blue are required but all will not cause any problems.
and every now and then i see a user id flash on screen of pro96 but its not stopping.
This is a classical indication you have not set the table as per my previous, or you have the table set incorrectly.
but when i put it on manual i hear activity.is there something i'm doing wrong.
Yes, check table.
i program using the scancat program
Worthless for Motorola VHF/UHF programming.
BTW, when you do see an ID on line 4 without any voice -- note what VC frequency is displayed on line 2. It will be a frequency not listed in RR Database. IOW, the incorrect table setting will force an incorrect VC, thus no voice.
The following is copied from my programming short cut link.
For VHF and UHF 400/500 additional steps must be set as follows:
1. Press PGM
2. Press TRUNK
3. Press FUNC + 2
4. Key in the Base freq then ENTER
5. Key in the 3 digit Offset then ENTER
6. Using the up/down, find the correct Step on line 4, then ENTER
7. Press FUNC + 3
8. Using the up/down, find the correct setting on line 4, Table, then ENTER
9. Press SCAN
Robins tables are listed on the RR Database page under Custom Frequency Table. Step=Spacing.
