lexmedic157
I'm sure I could get all the TG's, but I'm a little gun shy about listing everything. I don't have a problem with submitting for F/R as I've had most of my hand in that, but for LE, I don't want to step on toes.
Will the system start in Phase 1 mode or will it go straight to Phase 2 mode?
Also, curious if JMU police has plans to join the system or will they stay on their conventional repeater....
Sent from my Classic using Tapatalk
It will be phase 2 out the gate. The only time it will be phase 1 is if a medevac helicopter drops the talkgroup to phase 1 or a mobile repeater is activated which will drop a talkgroup to phase 1.
Thanks for the info..... Oh, and DOH! Lexington, not Harrisonburg. For some reason I always get Rockbridge and Rockingham switched up in my mind....
The dispatch channel will be patched in to the new system. Those with old pagers will be notified. 3 analog repeaters will remain online in case outside jurisdictions do mutual aid
Frequencies?
CTCSS tones?
The reason I asked, when Amherst County migrated to trunking, the old Sheriff Department repeater (155.520 MHz, 192.8 Hz) was re-purposed for this role, not any of the old Fire or EMS frequencies.
I’ll make the adjustment on the website on or just after April 12.
Thanks. When available, I like to have the conventional paging channels programmed into a radio also.
Tried sending you a PM but it wouldn’t let me through Tapatalk
