Rocket Broadcaster - Credential Error
W4UO
Gatlinburg, TN
I'm having an issue with rocket broadcaster logging in to broadcastify. Im using the correct feed credentials from my feed technicals page. When test the setup is fails trying to login . So im at a loss. Anyone run into this before?
W4UO
Gatlinburg, TN
Nevermind it was my goof. I needed to leave the username blank. Thats all it was.
