KA1RBI
Thanks! Started a new folder from scratch and did the checkout first, that got it.
just to note, the new rx.py version has enough changes in it that it won't run correctly using an install of the "old" version of OP25. Accordingly, I recommend that you do a "sudo make uninstall" from the "build" directory of your previous installation. Then do a full build/install of the new version (after checking out the "max" br)...
Max
