I need to adjust the file I am currently using to be more suitable to my needs, which is strictly to use a P7100 as a glorified, high performance scanner.
I'm an experienced RPM and ProGrammer user and I've been doing this for years.
But, I'm now using a file that was built by somebody else, one which has a lot of updated group information in it, info I didn't have direct access to.
The problem is that this person arranged the systems and groups so that there are only 16 groups per system, which is logical for an authorized transmitting radio, say one used by an active LEO, but for scanning purposes it's anything but optimal.
So, I have, to describe an example, a large department using 48 talkgroups divided into three separate systems, each with 16 talkgroups.
I want to merge all three into a single department system with all 48 talkgroups in it. The radio will scan up to 50 talkgroups in a single list and for scanning purposes this is a better setup.
I have not found any way to copy, paste, or drag and drop the talkgroups around and merge these systems into one.
Does anyone know of a way to do this? Since I have not found it, I am operating under the presumption that there isn't one, as I've been using RPM for years and never found it, But it can't hurt to ask. Maybe someone has a way.
Otherwise, the process of transferring literally hundreds of talkgroups from one system to the next is going to be very time consuming. One at a time, I don't even want to think about it!
I like RPM, it's very logical and orderly, and generally better than Motorola CPS, but not in this case.
Motorola makes it much easier to perform the same task I need to do now.
