RPM
gzusizld
Elwood, IL
I purchased RPM early last year. Until now I've only used the programmer portion. Today I have a need to use RPM, the RPM opens, however I'm getting errors such as cannot find directories and folders. I tried the disk and ran repair and it's doing the same thing over and over. I registered the software when I installed it. Any ideas?
RPM SK-04768 R8B
LMR_Dude
What directories and folders are missing? During RPM setup you point out where RPM should look for personalites, radiobin, global set etc, Those are defined under TOOL, OPTIONS AND DIRECTORY SETTINGS.
IF RPM just wont run then I've got no idea.
gzusizld
Elwood, IL
Thanks for your help. I recreated those directories, and now it opens. Each time I go to read a radio I get the error " serial port in use" I assign a port,(com 3) then go to read radio again then I receive an error "Unable to write the XML file to disk" Finally I read the radio and try to save it. Again I receive the error again, Unable to write the XML file to disk. Each time I try to save a File (profile) I receive the error - Unable to write the XML file to disk. Any suggestions? - BTW- I did re-install the program over a couple times.
cabletech
Puget Sound
and do you have the latest ver of .net on your computer? RPM and a load of other programs have to use this .net in order to run correctly.
Forts
Ontario, Canada
Are you using the current version of RPM (R9C I think)?? I haven't seen any issues like that before...
