RPM2 "Control Channel TX Request
2wayfreq
NM Kirk City
Under P25 Trunked---> Misc Options. If "Control Channel TX Request" Is checked, is that Transmission Trunking instead of Message?
ElroyJetson
Straight from the RPM2 help file. (Search in help, "control channel tx request")
Control Channel Tx Request
Control Channel Tx Request​
This control allows the user to determine if the radio always goes to the control channel, even on message trunked calls, to request a working channel on a P25T system.
The radio always goes to the control channel to request a working channel.
The radio does not always go the control channel to request a working channel
Default: Disable
wa8pyr
Staff member
Lead Database Admin
Ohio
Default: Disable
Can't recall what all the technical details were, but I had mistakenly checked that box on some codeplugs I built, and was reminded that it wasn't necessary. If I recall correctly, this is a feature that only applies on Harris systems.
