RR Broadcaster - choose default sound device
camphill
Imperial, PA
How do I choose a default sound device on startup? I have two sound devices and when RR Broadcaster starts up it chooses the system default, which is not the one I want to use.
Also, I mistakenly clicked "Add Encoder" and now no matter how many times I delete them they come back at startup.
kendrik578
Live Audio Administrator
Greensboro, NC
You should be able to change those settings in the diagram below. As far as the encoders coming back, you have to have at least one and the other ones you don't need. R click and choose delete. If you continue to have problems we recommend all broadcasters to switch to Scannercast ( A lot more reliable).
