mtc
Can anyone guide me how to get rr live audio on a nokia E71?
thanx
much luv
thanx
much luv
thanx
much luv
Try Moodio. You can set up nearly any type of stream, and it works with nearly every type of phone. I was using it on my Blackberry until I discovered BBScanner.
Welcome to Moodio! | Moodio
from their site:
"Almost every modern phone with internet and multimedia capabilities should be able to receive radio through Moodio. What you basically need is a phone that supports 3GPP/3GPP2-streaming and understands the AACPlus-codec. This includes popular phones from manufacturers like BlackBerry, Nokia, Sony Ericsson, Samsung, Motorola, etc. Apple's (non-3GPP-compatible) iPhone is also supported."
Hmmm... I'm thinking that shouldn't matter. It uses a web interface to set up and select the stream, then the stream kicks over to the phone's media player, which is just HTTP on a different port. But if you've "been there, done that" I suppose it doesn't do what you want. IMHO--What good is a smart, fancy phone without a data plan???
BTDT ?? what is btdt?
Use Internet Radio application on E71. Open the app add station manually. I get the url when I view link in winamp. Example audio4.radioreference.com:80/880888742 add this manually and it should load CHP Golden Gate. I tried WINDOWS url links but couldn't get them to load. WINAMPS urls work.
Have Fun!
Mike
The purpose of having WIFI on a phone is so you don't have to use the 3G data connection! I suggest you try some of the suggestions that have been offered here. It seems that there have been at least two valid solutions given: Moodio, and the Internet Radio application as outlined in the previous post.
I'm wondering what you use your WIFI connection for, since you seem to be convinced that not having a data plan is the problem.
Done with this thread.
No hard feelings, I just feel like I can't help you further because I don't have a Nokia phone. I do hope you get it working.
Jeff
thanx
much luv
#EXTM3U
#EXTINF:-1,Columbia County AWIN System
http://relay.radioreference.com:80/708233863
