RS Antenna
aar9sm
I have recently bought the RS 20-176 108-1300 for $25.00 dllars and was wondering if anyone has both the RS Discone and 20-176 and if there were any drastic changes or improvements using the RS Discone. Iwill monitor mainly Vhf hi band and the Mil-air bands with some 800mhz
Mike
hsdtech
S.E. LA
Stick with the "sputnik". The R.S. Discone just plain sucks in my opinion. The elements always end up falling off, and performance just isn't worth it for the price.
I switched to the Scantenna and have never looked back. I still have my little sputnik (20-176) though, great little antenna.
LarrySC
Greenville, SC
The main issue with the 176 is the SO-239 female connector for a PL-259 plug. They are not rated above 600 mHz. Rather than use coax that requires a PL-259, insert a PL to "F" adp'r and use RG-6 with "F" connectors which is rated to 900 mHz. This will help the 800 coverage. Add an "F" to BNC adp'r to your scanner.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
I'm going to try this first. I kinda wish I would have gotten the Scantenna or a Diamond Dipole. there is another thread on here with using a cell phone antenna and a diplexer. you can get the diplexer here:
http://tinlee.com/
hsdtech
S.E. LA
http://tinlee.com/
What antenna do you have now? The 20-176?
mike_s104
I bought the PL-239 to F connector adapter tonight and I had an F to BNC. I installed them with a short piece of RG6 good up to 2.25GHz. the antenna seems to be working better. there is an 800MHz trunked system that I was unable to receive with the other cable I was using with the PL-259 connectors, now I can receive it. thanks LarrySC. :)
prcguy
Any improvement will be due to the coax you changed to, not eliminating the PL-259. A PL-259 to F adaptor is still a PL-259 at one end. Where did the 600MHz rating on a PL/SO-239 come from? An SO-239 that terminates directly into antenna elements as in the Sputnik becomes part of the antenna and losses would be negligible. There are high quality versions of SO-239s and Motorola has used them up to 860MHz in the past. Where did the 900MHz rating on F connectors come from? Most that I see and use are rated to beyond 2GHz with a very good match.
prcguy
mike_s104
prcguy
I figured it was the coax more then the connectors. I went with the F connectors since I have a lot of them at home. regardless of which was to blame, it's been some what fixed. I still may try the Scantenna also.
