RS Pro 91
#1
Can I use the Pro 91 to listen to an agency that is using an analog radio frequencies of which are shared by another agency that uses the same frequencies but those frequencies are AP 25 digital and not have the digital noise from the AP 25 side of things?
buddrousa
NW Tenn
#2
After reading the user manual I see you can not add ctcss tone squelch codes to this scanner so it is open squelch and no way to block P25 digital.
