RSO freq in San Jacinto
brandon
SoCal
They are on the Riverside County EDACS trunking system:
1 - 866.3125
2 - 866.8125
3 - 867.3125
4 - 868.3125
5 - 867.8125
6 - 867.7625
7 - 868.8125
Dispatch is on the Cabazon group ID 549 and Car-Car on 546. I believe Ch-3 is 545 and Ch-4 is 547.
More talkgroup info can be found on Scan Riverside
-OR-
Just monitor them on 855.9875 and call it a day :D
zz0468
175 DME, HEC 358° Radial
The 855 channel is patched to a single talk group so, while it's great for listening to dispatches, you'd miss the car-car traffic, and various other things taking place on the trnkled system. That's located at Mt. David, by the way, and simulcasted with Whitewater on the same frequency.
