RSS Dropped off
Jawjuh :)
#3
I just checked and mine is fine.
For example, I use this for California:
Code:
http://www.radioreference.com/forums/external.php?type=rss&forumid=37
maybe I'm nuts, but I cannot find a list of "forumid" numbers manually or using search functions here on RR.
Anyone got an answer as how to find the 'forumid' for selected forums? :(
Reason is to only download via RSS the forums i have interest in, as opposed to all ;-)
Tom
Jawjuh :)
#6
forumid vs forumids (plural)
Thanks, Wayne - I know you have a lot of things to deal with, and the list helps, but as on last question.
I previously understood you could monitor selected forums using a following manner URL extension:
type=rss&forumid=37,44,66,5,12 (Didn't seem to work)
Or was that required to change "forumid=" to "forumids=" (plural) when doing multiple subs?
IF that works... ;-)
Tom
Jawjuh :)
#7
Solved.. ;-)
Tom
FUGGETTABOUTIT!! :) Just scrolled down on the referred page w/list and found this
radioreference.com/forums/external.php?type=rss&forumids=6,7,8]The RadioReference.com Forums - 7,8
S is needed, apparently - will try it out formatted thus.
Thanks again, Wayne (P.S. - we have a guy (Wayne) in our club whose license-plate call tag is : "W4YNE :) )
73 (no "s")
Tom
