I have just received a Retevis RT8.
I am not exactly a novice, but I just cannot work out this problem.
I have a local DMR station that I am trying to listen to.
I installed the driver/software etc an that is up and running.
I have programmed in an Analogue local station. That works. The same 'L' an X are always present on the screen, but the squelch opens and audio is received. So the radio is working.
I programmed the DMR frequency, Color Code and Slot OK (got that info from my Whistler Scanner), as Channel 1.
Some of the transmissions are clear, some sound like basic encryption, on my scanner . no audio on the RT8 ever.
Now to the RT8 specifics
1. The display shows Zone 1 Channel 1 and the name I assigned to the channel is moving from right to left. The green led at the top is showing.
2. The Loudspeaker Icon has an X next to it at all times There is a square with 'L' in it to the left of that. (Does that indicate the channel is 'locked'?)
3. I am sharing the same antenna between the scanner and the RT8.
4. When the station transmits it appears on the scanner, showing details, and there is audio. Nothing on the RT8.
5. No audio on the RT8. Pressing button 1 re 'MONITOR' has no effect. No Icon shows as in an analogue channel.
6. I also set up a long press to what I think should be the de-scrambler. Still the 'X' and no audio.
7. There is an 'S-Meter' reading.
8. The two logos on the right are
a. a shield with 2 blue quarters (if I ong press Button 1 that changes to red).
b. an arrow pointing right
I am presumably missing something.
Any help would be very much appreciated. An 'Idiots guide' is probably best, lol.
Cheers
Cheers
