rtl sdr after serial number change, device no longer works in windows.
hhca
Australia
Ive got this behaviour which would seem incorrect to me where if i change any of my various 'v3 blog' dongle's serial to anything other than their default 00000001 they stop working in windows. They still work in linux and if i revert them back with linux rtl_eeprom they work again in windows... In windows SDR# it will show the dovice in config but when pressing play "Cannot access RTL device", device manager shows it as installed with no errors. I can live with this as linux is the only time i need more than 1 plugged in, more just posting this as an account of my problem. tried serial numbers 00000101, 00000002, 102, no difference, also tried setting in windows with rtl_eeprom.exe but that then make the device say it has no eeprom and have to use linux to revert it back.
RTmed519
I used a different program to change my serial numbers. It was like RTL Tool or something. I can try to find it later tonight.
maus92
OCMD
rltool works - all my rtl devices have unique serials, and I used rtltool to change them from their default value. All work with sdr programs on multiple Windows 10 Pro machines.
morfis
I have re-serialed dozens of rtl devices (most nooelec models, rtl-sdr.com models, old DVB-T dongles) using rtl_eeprom.exe
Never had any issues, never needed to re-install drivers.
As a417 says above...don't mess with switches you don't fully understand.
Create a batch file with the command, switch and serial number in the rrtltools directory. Remember you'll need to change the number in the batch file manually (unless you do a posh batch file with variables like good old DOS days) before running for each device. Add a pause so you actually see the command output.
rtl_eeprom -s 21000012
pause
If you would rather use a GUI then download jdow's rtltool package
People have used letters and fewer numbers but I have always found numbers give sufficient flexability to uniquely identify the device, it's chipset and manufacturer
AM909
Radio/computer geek
SoCal
I changed the serial from "00000001" to "12340002" on my NooElec with rtl_eeprom on Win10. Just to be safe, I also dumped the EEPROM to a file (with -r) before re-serializing, just so I could restore from it if necessary. I dumped it after re-serializing and compared hex dumps of the two files. The change was the serial number, stored in little-endian 16-byte Unicode chars starting at position 0x37, and 0x12 at position 0x08 changed to 0x02.
hhca
Australia
Hey I got it to work !! Did just have to reinstall Zdiag Winusb driver "options->tick show all devices & untick ignore hubs... funny that it works without different serial number off default driver but not after. Also had to zdiag install both my devices even though identical.
