Exactly! I quit using the Pi's when they became scarce during COVID and all of the price gouging started. I've since moved
onto surplus Small Form Factor (SFF) PC's that flood the market, are very inexpensive, and way more powerful in addition
to being virtually self-contained.
What really kicked them around in the dirt for me was the issue that they had with chokepoints & bandwidth limitations. So many of the bloggers and so-called 'techies' pressed them into service doing things that they weren't
just meant to do.
It came into life as a proto board, it's still a proto board.
In 2014(ish) when the 2B came out, people said "zOMG I can MAEk THis INTO a NaS!", and they did...and then the bloggers hit it, and then it rended it...and homegamers and tag-a-longs were making them into NASs, and they started saying "wait...why am I only getting sustained +- 2.0mb/sec writes on my NAS? It takes forevvurr to save my 4 gig hentai mp4s", etc. Sure it's a great device, but it has
YUGE disadvantages in the way that (if i remember correctly, it's been nearly a decade now) the networking device was on the same USB host as the exposed ports...so you can only imagine what would happen when the USB wifi adapter and the external USB device were trying to process a huge data transfer. Yep, fell flat on its face. The same thing happened when people said "oh I can make this a smart camera to watch Mr Piddles sleep in his doggie bed, when I'm off at the coffee shop working on my screenplay"...and then were shocked to discover that the high spec USB camera they attached was limited to like 320x240 @ 3 fps with
MASSIVE latency. Decent for one camera if you're monitoring flowers, abysmal for anything more than one/or anything with a +2 FPS requirement. Nearly every person's post-mortem of those projects shared the same realization. It's "great for prototyping, but to do what I want will need more powerful hardware." Meanwhile, all that demand and the trending destroyed the supply chain for them and drove prices up to unreasonable levels (IMHO).
It can do these things, but more for proof of concept, not for any real production element. It's still a protoboard to me, no matter how much lipstick they want to slather on it. I've got one of the first 1B+s, a 2B, a couple of 3B+s and a handful of Zero 2 Ws - and they are all entrenched in a firmly static environment. One's a RTOS smart thermometer, one shows a google calendar on a TV, another controls outdoor lighting, and another makes my garage doors, heaters and lights "smart" thru a microcontroller...but none of them do any sort of heavy lifting, much less streaming anything. Not a single one of them employs a GUI, the one that displays a calendar doesn't even have a DE on it - it literally runs chromium direct to X. The refresh time is measured with a calendar. They just aren't cut out for that.
Personally, I can't imagine a situation where I would need one of them to run SDR in any capacity. Perfect example, I have an RTL_TCP instance running on a Linksys wifi router. Yes, a raspi could do that for me - but the linksys is already where I need it, has a wired connection home, and has an unused USB port.
