RTL-SDR using Ultitrunker Help
thinbluebbq
Franklin, IN
Hi all. New to SDR and I have the RTL-SDR V3 dongle and am trying to use Ultitrunker software. Shows it is running but I am not seeing anything so looking for help in configuring things if someone has experience setting it up. Thanks!
silberj
Vine Grove, KY
If you want to spring the $10, DSD+ Fastlane eliminates the need for Unitrunker all together. I'm very impressed. DSD+ combined with the included FMP24 works like a boss.
While I agree with you about DSD+ it will not decode a TYPE II system. Also I find the audio decode on UT2 to be better and the decode info is easier to add tags to.
silberj
Vine Grove, KY
If you mean Phase II it actually does. As far as the others go, I'll take your word for it. :)Annotation 2020-08-15 113225.jpg
