SDR# RTL433 Plugin For SDR# Now Available
Dirk_SDR
Germany
I had no chance installing this (and other) plugins on the new SDR# version 1842.
Just copying dlls and adding a html text line in plugins.xml doesn't work anymore. They don't appear in the SDR# menu. The last version with which this was possible was 1836.
Does anyone know how to add this plugin to 1842 and up?
Marco402
Hello Dirk_SDR
For SDRSharp 1830 and 1842 just put the 3 dlls in the plugins folder or better in a subfolder for each plugin.
it's ok for RTL_433.
Marc
hamradionl
Also test using
SDR# 1811
868MHz
POPUP on minitor screen
************** Exception Text **************
System.ArgumentException: An item with the same key has already been added. Key: [0, 0.000 days]
at System.Collections.Generic.TreeSet`1.AddIfNotPresent(T item)
at System.Collections.Generic.SortedDictionary`2.Add(TKey key, TValue value)
at SDRSharp.Rtl_433.FormDevicesListMessages.setMessages(Dictionary`2 listData)
at SDRSharp.Rtl_433.Rtl_433_Panel.addFormDevice(Dictionary`2 listData, List`1[] points, String[] nameGraph)
at SDRSharp.Rtl_433.Rtl_433_Panel.<>c__DisplayClass31_0.<addFormDevice>b__0()
System.ArgumentException: An item with the same key has already been added. Key: [0, 1465.090 kg/h]
System.ArgumentException: An item with the same key has already been added. Key: [0, 0.000 kg/h]
sjacket99
FuzzThePiGuy
Pa
Hello sjacket99
Can you give me your screenshot.
Marc
Here is the error that I got using version 1811. But on the newest release revision 1842 (2022-01-08). I didn't have any issues so far.
Marco402
Hello hamradionl
-Delivery of version 1.5.4.2 on Github.
-Modification of the code to add the columns in dynamic and not when opening the window.
For new devices (LORA monitor), you have to see with the programmer of RTL_433: GitHub - merbanan/rtl_433: Program to decode radio transmissions from devices on the ISM bands (and other frequencies) Open a new issue.
When closing the Verbose window, SDRSharp also closes->it's normal.
For info yo can found some informations for devices-->
for multiple ID'S, i can separate devices with id(I have to test). Currently, I test the Model, channel and protocol.
I hope it's ok for you
Marc
hamradionl
SDR# 1700 first test
When set verbose to NO -v i only seen the honeywell
When set verbose to -vvv or -vvvv IKEA sparnass only decode no longer see the honeywell
And after some time the verbose screen is stoped scrolling and crash
at SDRSharp.Rtl_433.dll.ClassInterfaceWithRtl433.searchZero (IL offset: 0x44)
at SDRSharp.Rtl_433.dll.ClassInterfaceWithRtl433._callBackMessages (IL offset: 0x3a6)
at SDRSharp.Rtl_433.dll.NativeMethods.receive_buffer_cb (IL offset: 0xffffffff)
at SDRSharp.Rtl_433.dll.ClassInterfaceWithRtl433.send_data (IL offset: 0x115)
at SDRSharp.Rtl_433.dll.Rtl_433_Processor.ProcessRtl433 (IL offset: 0x49)
at mscorlib.dll.ThreadHelper.ThreadStart_Context (IL offset: 0x25)
at mscorlib.dll.ExecutionContext.RunInternal (IL offset: 0x79)
at mscorlib.dll.ExecutionContext.Run (IL offset: 0x0)
at mscorlib.dll.ExecutionContext.Run (IL offset: 0x2b)
at mscorlib.dll.ThreadHelper.ThreadStart (IL offset: 0xf)
Marco402
Hello hamradionl
-vvv and -vvvv can crash the application, it would be necessary to detail each device.
Use these options only if necessary to the risk to plant.
For the Honeywell device, I don't have this device or cu8 files to try.
Do you have the RTL_433.exe application for console window to see what it looks like, which would allow you to save .cu8 files and send them to me in a . ZIP via github/issue.
Marc
hamradionl
When use verbose NO -v honeywell is there.
SDR# 1700
When heavy decode multiple units, the SDR# freq window for a very short time (1 sec) seem get stuck or pause
Honeywell found over 50 devices
using verbose -vvv or -vvvv
i look what is missing from decoded screen, this why i found the Philips, IKEA who not popup when use NO -v
hamradionl
SDR# 1811
DEVICE RECEIVED LIST
433 MHz frequency shown in the 12e colum named FREQ
868 MHz Honeywell the frequency is set to somewhere on the end in colom 30 - 40 named freq-1 freq-2
868 The colum FREQ stay empty very long info stream need to scroll to right
hamradionl
Thank you, looks good
SDR# 1811
868 MHz
LIST DEVICE + LIST MESSAGES
freq-1 freg-2 in 9e and 10e row :)
LIST DEVICE
- UNKNOW row Contain some data
Let this version run whole day, report later unless if crash
Marco402
Hi
which device are you talking about?
Honeywell 921 has this column :
"model",
"id",
"datetime",
"domain_id",
"state",
"demand",
"status",
"zone_idx",
"max_flow_temp",
"pump_run_time",
"actuator_run_time",
"min_flow_temp",
"mic",
Marc
hamradionl
LIST DEVICES
868
RTL433 set to:
-CSi
-Mlevel
Honeywell CM921 idxxxxxx:
Device
N mes
time
protocol
model
integrity
device ids",
UNKNOW
modulation
freg 1
freg 2
RSSI
SNR
NOISE
Boiler mod level
Flame status
TEMP zone
Some other CM921 data string contain a very long list, many rows :)
Marco402
Hi
I have the explanation for UNKNOW.
I don't understand why Mlevel's options are not at the end.
If you want to go further, I need the .cu8 messages
In the list of devices select Honeywell 921(185)
Check Show Select.
Check -SKnown.
Wait for a few messages located at RTL_433.dll
Put the .cu8s in a .zip file.
Send them to me on Github by opening an issue.
Marc
