RTLSDR and Raspberrypi as Broadcastify server - DMR
hydes2004
I`m trying to usean RTLSDR dongle I have.
I want to use the dongle along with a raspberrypi to decode the DMR data and then use the broadcastify client. has anyone tried this? Right now I use sdrsharp and dsd plus, but there is no way to set the squelch
boatbod
Talbot Co, MD
op25 has the capability to monitor BS simplex and MotoTrbo Con+ DMR. It presently does not handle Tier III, MotoTrbo Con+, or tdma simplex.
hydes2004
OK, so I changed my setup. I have a spare PC with an RTL SDR Dongle, I was to track a single freq DMR system and feed to broadcastify. I also have a USB soundcard attached and vb cable installed. I only want the decoded audio to be sent to the stream. Anyone have a similar setup?
a417
yes. that is basically what EVERYONE who streams audio to Broadcastify does. (with the exception of those who use stuff like Barix streamers, etc...)
hydes2004
I understand that, my issue is i need to decode the dmr and output the audio only for the stream. vb cable is installed and i have a usb soundcard with the input/output tied to each outher.
hydes2004
I got it worked. Major issue now is sdrsharp hangs and crashes randomly. Joy
