Rugged Radio Antenna
Kzneft
West Jordan, UT
I really can't get an answer to my question from Rugged Radio so I will post it here as I am sure there are lots of smarter people here then me when it comes to antenna's...
Have a Rugged radio in my SxS and get almost no distance when transmitting (Like 100 feet). I checked my cable from my Rugged Radio to my antenna, and it looked like it got very hot and noticed some melted shielding. I know I need to replace the cable, but I thought maybe I would check the antenna to see if there was a short or something that might have caused the cable to get hot in the first place. I put my continuity tester between the antenna and my frame (ground) (see pic), and yes there was a connection. I thought that was odd. I then checked the connection between the antenna and the center of the connector that is supposed to connect to the center wire on the coaxial cable, and it was an open circuit. Isn't there suppose to be continuity between the center pin and the actual antenna, but no connection between the antenna and ground?
Project25_MASTR
Millennial Graying OBT Guy
Texas
Depends on the antenna design. Only way to really test is to either grab another antenna and see how it performs or test the return loss of the antenna.
Half wave antennas like that will often show a short between the ground and the whip as the coil passes DC.
As for connection to the whip, there may be a capacitor in there, but like ^^he said above^^ it depends on the exact design.
If you are looking for a replacement, I've been running these on top of a few UTV's successfully:
I haven't used this antenna specifically, but I've found EMWave to be an excellent brand and worthy of a try:
