I was asked this by a friend of mine looking into ham radio. I was just wondering if that I could run a couple antennas of one 75 ohm coax line? I have a feeling that its not possible but I and the other guy were just curious.
Although the sticky is good... just to clarify though since you mention amateur radio, if we are talking about anything other than just receivers the answer may be no. You can not put multiple transceivers on the same antenna/feedline unless you are using duplexers and they are on different bands. Also, you would then be using 50ohm cable and not 75ohm.
