ProScan: running proscan
deklund1955
Wellesley, Mass
I am trying to run Proscan on my windows 10 machine. when I try to run it, it said that I need net 4.8 which can't be installed on windows 10. I have version 7 of NET, but proscan will not run.
I had this running before I had to reinstall the O/S.
TIA for any help
Don
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Not true. I have it installed & running fine on Windows 11. Run Windows updates, at the very least you need Windows 10 version 1903 for .NET 4.8 but it wouldn't hurt to go all the way to 22H2. Welcome to the RR forums
Operating systemSupported editionsPreinstalled with the OSInstallable separately
Windows 10 May 2019 Update
(version 1903)
32-bit and 64-bit.NET Framework 4.8-
Windows 10 2022 Update
(version 22H2)
32-bit and 64-bit.NET Framework 4.8.NET Framework 4.8.1
TFOX9
TFOX9
please forgive me i don't really mean to bumping Old Post here but ProScan With Our Amazing And Wonderfully Lord's Help Through @ProScan for giving him the created idea to create this program is one of the best Scanner software programs out there to date in both my God Almighty's book and mine as well. with all of this say however i have the very latest version download here verison 23.2 i whenever i try to download and instill
(version 1903 it gives me this error pay no attention to the + 5,000 tabs here and i just download the latest version of .NET Framework 4.8.1 i have both
.NET Framework 3.5 which includes .NET 2.0 AND .NET 3.0 and i have .NET Framework 4.8 Advanced Services with everything check mark please forgive me my spelling is not very good I do have dyslexia if you guys or evening better Proscan can help in anyway I'd really appreciate it and again sorry for bumping an Old Post Tom TFOX9.
ProScan
Software Provider
Ontario, Calif.
What happens when you download ProScan from the proscan.org web site and install it? Does ProScan startup normally?
BTW, ProScan targets the .NET Framework 4.8
TFOX9
TFOX9
yes everthing install just find but it's not startuping up normally and i already have the 4.8.1 Web Installer when i click on yes that's the website it send me to right here Download .NET Framework 4.8.1 Web Installer when i try to download the other
(version 1903 that Whiskey3JMC talked abouts and looking on google it comes back as KB5039299 right here i keep getting that error one more thing i may mention as well I've been trying for a long time to update the latest verison of os update 2024-01 Security Update for Windows 10 Version 22H2 for x64-based Systems (KB5034441) and it keeps giving me that error that it can't instill btw iam on verison 22H2 os build 19045.4651 1722233210942.png
ProScan
Software Provider
Ontario, Calif.
The .NET Framwork 4.8 should already be installed on Win 10.
I would reboot your computer, if ProScan still doesn't start then perhaps it may not be a .NET Framework problem but rather a ProScan config problem such as the screen is minimized or out of bounds of the display so in these cases, go to the ProScan folder and rename (in case you want to revert back to the prior config) the ProScan.cfg file or delete the ProScan.cfg file then try starting ProScan again.
TFOX9
TFOX9
With Our Amazing And Wonderfully Lord's Help you sir are a genius all i had to do is delete the delete the ProScan.cfg it has expired but I don't care at least I can see this now after so many times trying to get this to work it's always just one little thing with these computers and one little fix makes it all work again will some times Thank You Thank You Thank You Bob soooooo much.
