runtime error when trying to get Live Audio
emt-medic321
Ohio
#1
I keep getting a runtime error when attempting to connect to any of the scanner feeds. The error states, it's a Microsoft Visual C + + Runtime Library Runtime Error! Program: c:\Program Files\Internet Explorer\iexplorer.exe This application has requested the runtime to terminal in an unusual way. Please contact the application's support team for more information. I have a laptop with Intel 3.2 processor, 1 GB ram. Win XP Pro SP3, IE8, Lastest updates, latest Java, Media Player 11. This is the same as my desktop and it runs just fine. Any Help ????
rwmitchell
Mid-Michigan
#3
Runtime error
With IE8, I've had similar problems. Try checking to see if your in "Compatible Mode". Tools > Compatibility
Just a thought, IE8 is sensitive with Visual C+ compatibility.
