RWC Towers Mtn now on line
rwier
Phoenix, AZ
Thanks, John. Not in RR at this time, correct? Do you have a location (or mountain peak name)?
radioprescott
East Central Arizona
SID: 0534 (RWC)
Towers Mtn Site 111
cc 772.49375
voice ch 773.99375
Traffic heard on TG 4141,
A6 switching to ??? channel
291 at an address on N 124th Ln
211 enroute to the call 439
221 in service.
Peoria PD is TG 4141 on the RWC...does this sound like them?
kb7yvx
Prescott AZ
SID: 0534 (RWC)
Towers Mtn Site 111
cc 772.49375
voice ch 773.99375
221 in service.
they must had started using it the past 2 days,,i monitored it most of tuesday and all i had was data thru the whole day
Arizona_Scanner
Phoenix, AKA HELL
SID: 0534 (RWC)
Towers Mtn Site 111
cc 772.49375
voice ch 773.99375
221 in service.
Why on earth would Peoria PD ever need another site other than the one on the White Tanks. That is super high up and will service any part of Peoria with ease. Transmission from White Tanks can be picked up almost anywhere in the valley for the most part. Just curious if anyone knows.
radioprescott
Towers Mtn, Mt Suppoa, North Mtn, Sacaton Mtn, and several of other "high" sites not yet in the RRDB, are designed to extend the RWC footprint outside the normal simulcast area. Its similar to the Yuma system with sites all over SW AZ.
White Tanks appears also to be a "high site" based upon the RWC documents that have been posted here; it was set up as a interops demonstration project during the Super Bowl some years ago (before there was a Simulcast G), and is still used for events on the west side. The local agencies likely are affiliating with it just like Peoria occasionally does with Towers. Peoria is likely assigned to Simulcast G as its primary. If someone could run two instances of Unitrunker (Tanks and Simu G) and compare, you might see the relationships.
With the multiple sites/simulcast/systems in the Valley now, you can expect almost any agency on any system!
Arizona_Scanner
Phoenix, AKA HELL
I honestly don't know why Simulcast G has to exist. Peoria, Surprise, Buckeye, all use the WT site and it covers everything. El Mirage is the only agency I am aware of that uses Simulcast G exclusively. I have seen the Simulcast G site...it is a small tower about 40 feet tall in the middle of a populated area....it's coverage stinks compared to White Tanks. You have to practically be standing under it to pick up El Mirage PD.
Astrak
Mesa, AZ
Different talk groups have different site permissions, like A1 is allowed on G, Quintero IR and White Tanks where as say A4 Events is only allowed on Quintero IR and G. A6, B6 and C6 along with some other encrypted talkgroups are allowed on B, F, G, Quintero, Outlet Mall, Estrella and White tanks.
radioprescott
.... I have seen the Simulcast G site...it is a small tower about 40 feet tall in the middle of a populated area.....
By definition, "simulcast" means more than one site transmitting the same information on all frequencies simultaneously. The license for Simulcast G shows several sites.You likely found one of them. The other sites will give varying degrees of coverage throughout the simulcast footprint.
WQJY471 (Peoria, City of.) FCC Callsign Details
Or maybe you found Site 502 Quintero, an IR site affiliated with G that offers enhanced coverage for a particular area of the footprint.
So between G and 502, they likely have more solid coverage for building interiors and low-power handhelds that just relying on Tanks alone.
Here's what was posted awhile ago...http://forums.radioreference.com/arizona-radio-discussion-forum/178852-rwc-presentation-april-2010-a.html
My 2 cents anyway...:eek:
