RX signal
JamesBrox
Santa Rosa County, FL
Weird, it's not doing today. I have 1000G+ paired with a GMRS Ed Fong @ 30' elevation. Location is 20 miles north of Pensacola, FL.
WRXU693
James
weyforthr
Stafford Virginia
I have the KG-1000G Plus, as well as a pair of 805G HTs and have observed the same "issue". I attribute the aforementioned signal indication as either a very sensitive (super heterodyne) receiver, or an intermittent RF "noise" source. I tried increasing squelch but that did not make a perceptible difference. It's a minor annoyance that I can live with for now.
JamesBrox
Yeah, it's a minor annoyance. Just thought I'd ask, thank you for your reply.
WRXU693
KK6HRW
My H/T will stop scan on a signal, but not break squelch (to allow voice), if my receiver is set to the wrong CTCSS/DCS ‘tone’.
Bill R
W8UU
Pilot of the Airwaves
Wellston OH
Bill R
More than likely your radio is stopping scan because (Step #1) it senses RF activity on the channel, but Step #2 is to decode the tone and it isn't correct. Your radio pauses the scan function then eventually moves on and you hear no audio. It's a common problem with cheaper consumer-grade electronic products. That stuff drives me crazy and it's one of many reasons I buy nothing but commercial grade radio equipment. My Motorola, GE and Kenwood equipment scans really fast and seems to sense the RF and tone at the same time. You don't get the stop scan issue and you rarely get the first syllable clipped off. Even with a priority channel programmed, if you get the right commercial grade radio, the resample speed is so fast you don't get choppy audio on a non-priority channel. For me, I either had to learn to live with it or upgrade my equipment.
hill
Middle River, MD
More than likely something in your home or nearby is causing interfere to your radio.
With the amount of stuff in our homes today it could be anything like a cell phone charger, router, or even security lights have been the souce of interference that hams in our club have reported.
I guess you need walk around and turn off stuff to see if goes away.
It may even be in another house in your area.
amcferrin90
Pickerington, OH
If your radio is scanning channels and stops, it's because it is receiving a signal. If your programming has a privacy tone PL/DPL on the receive programming, the radio will wait to hear that matched tone before unmuting the speaker. Depending on the radio it may do another round of scanning because of the mismatch on PL/DPL. If you're not on scan, holding on a channel the RX led is there as a courtesy so you know the channel is in use and to wait until the channel is clear before transmitting. For me, I just don't program a receive PL/DPL and leave my receive as CSQ.
FKimble
Newnan, GA
As already mentioned, it's either interference from "something" in your home or neighborhood, or a transmission with a different "tone" than what you have programmed. Try putting in the same freq without a tone. This should allow you to "hear" the received transmission. If it's regular audio/talking, then its a station with a different tone. If it's static, then its interference from something nearby.
Frank
