BMDaug
I am licensed…
Hey everyone, I just built a man portable setup using a Harris XG-100M and a compactenna lmr-i. My question is, how much power is it safe to use?
*Regardless of radio and antenna make and model, I hope the spirit of this post is more in line with amateur radio than a “follow the manual” commercial install. My apologies if I’m out of line here. Please move this to a different sub forum if necessary.
Anyway, the radio will do 50W vhf and uhf. I’m pretty sure that’s not at all safe with the antenna less than a foot from my head. Harris says that at full power, “in a controlled environment” (this basically means an environment where there are no bystanders unaware of the transmission), safe distance is ~30” for vhf and uhf and ~8” for 7/800 mhz.
Most military man portables do around 20W (I think). Is 20W safe at that distance? It’s easy to switch between ”high” and “low” power on the go, but I need to define what these mean. High and low can be defined for each band via the programming software.
Anyone care to offer their opinion on what is a safe while wearing the pack?
Thanks,
Brian
Thanks,
Brian
