Safe-T System Towers
ILL
#1
Trying to match up the towers with the CC freqys for Indiana System when i visit the area in a couple of weeks....Map with tower #'s does not match the tower # CC freqys...Do i have this correct=Lake Co-Tower207, Newton-T237, Porter-T216, and Jasper-T208....Thank You....Ron in Joliet, IL
#2
Yep, your correct.
On the BCD396T the following control channels decode as:
Lowell A40Ah-0007
Porter Co A40Ah-0016
Newton A40Ah-0036
Jasper A40Ah-0008
Not sure why RR is listing them as having a 2xx. The only one that doesn't really jive if you drop the "2" is Newton. I tripple checked for you, and it is correct above (0036).
Hope this helps
scannerfreak
Moderator
Indiana
#3
XTS3000 said:
Yep, your correct.
Lowell A40Ah-0007
Newton A40Ah-0036
Jasper A40Ah-0008
Hope this helps
They have a "2" prefix because they are in zone 2. The map from the IPSC is their numbers for the sites. We use the Motorola site numbers as you provided above.. With your above info, it appears they changed North Webster to 35 and made Newton 36. I made the change, thanks :)
