Safe-t
indiana1983
Columbus Indiana
Does anyone know, If you have a scanner that can pick up 800 frequencies that you can programmed it to SAFE-T. I am just wondering. Bascailly I am asking if you have a radio that can pick up 800 radio frequencies could you use it to pick up SAFE-T.
XTS3000
Most TG's are digital, so you need a P-25 trunking scanner to listen to Safe-T.
rdale
Lansing, MI
Not quite, you need any scanner that does digital trunking - not required to be P25 since Safe-T doesn't use 9600 baud CC. So the original Uniden digital scanners will work too...
If you do not have a digital scanner you can try this link at the bottom it has the Safe T conv channels that simocast some times Safe T traffic it is also the channels outside agencys can use if they do not have Digital. There is not much traffic on there unless something big is happening on Safe T most of the time it Id's in code and you will hear some keying this does not half to be a trunking scanner to pick this up just somthing that can pick up 800MHz If you can not get pdf files I can post thoses freqs
http://www.in.gov/ipsc/safe-t/update/NPSPAC.pdf
Viper43
I doubt the "original" Bearcats could recieve these frequencies LOL sorry, I couldn't resist that one :)
V
rdale
Lansing, MI
Ha ;> That's why I said original Uniden _DIGITAL_ scanners...
