There are fire departments and firefighters in Indiana who insist that P25 digital communications with the currently-used vocoders is not appropriate for fire operations. They put up a fuss when asked to use digital channels on SAFE-T and they put up a fuss when MECA went to their all-digital P25 system. In at least one county which uses SAFE-T, the fire ops talkgroups are still analog because of this resistance to using digital.
Its not just firemen in Indiana. Digital radios on the fireground is a well documented danger to firemen, espically the first generations of radios.
http://blog.tcomeng.com/wp-content/uploads/2007/11/phoenixfireradioreport.pdf
http://www.iafc.org/associations/4685/files/digProj_DPWGinterimReport.pdf
Fire Fighter Fatality Investigation Report F2008-09| CDC/NIOSH
Recommendation #9: First responder radio manufacturers, research/design facilities and standard setting bodies should continue research and efforts to improve radio system capabilities.
Discussion: The use of personal protective equipment and an SCBA make it difficult to communicate, with or without a radio.12,13 Several NIOSH Fire Fighter Fatality Investigation Reports have cited issues with portable radio communication, and the International Association of Fire Chiefs has released an interim report concerning possible communications problems involving digital two-way portable radios in close proximity to common fireground noise.
