Sage Coaxial switches
fstuart
Baywood, La.
I have 2 Sage Labs motorized antenna coax switches and need to know how to wire them.
#1 is Model # SAN 360EL with a 8 pin military control connector. (1P3T) Type N connectors for feed lines.
#2 is Model # SAN 460EL with a 10 pin military control connector. (1P4T) Type N connectors for feed lines.
They are of the latching type switches and are both 28VDC switching voltage.
I can build desk power supply/control box's for them if I know what pins to use.
Any help would be greatly appreciated. Thanks Frank, N5BSC
fstuart
Baywood, La.
New Info: I have worked through both of these problems and I am in the process of building controllers for both switches. Thank you to all the readers and this site for giving us a sounding board.
Frank
N5BSC
