I see the Northeast RCS site according RR Data base has been rebanded to the new freq. My ? is how do you program the site for the Uniden BCD325P2 under the band plan on the scanner 800/900 stander,800 splinter, custom, And if its custom how do you go about doing it. I know how to program these scanners by its not a problem for me. Thanks Folks For The Info
If I am not mistaken, the NPSPAC (866-868MHz) frequency sites just get new control channels exactly 15MHz lower, and you unsplinter them. The non NPSPAC stuff gets the custom rebanded bandplan treatment. Can anyone confirm if that is how it works?
Paul
Don, out of curiosity, when a reband occurs, does the control channel just instantly change to the new rebanded frequency, as if this were 1998 at midnight?
I would guess that assuming the new control channels were in a scanner, all that would be needed to do once this was apparent would be to change the system/site splinter option to off?
Paul
OK, want to do the reband on NE, on a 996. Proscan doesn't show anything but the freqs, but FreeScan comes up with a reband calculator (under system type Motorola Custom/Reband Type II), with high and low freqs, and offset.
Anyone know which is better, and WHAT the info Freescan wants IS??
Is most of San Diego RCS still analog?
My apologies if this is the wrong place for this question. I've read through many of the discussions here trying to determine the answer to this question - here is what I've gleaned (anybody please correct me if/where I'm wrong).
- The San Diego RCS is in the middle of a multi-phase, multi-touch rebanding
- The San Diego RCS *right now* is still analog
- Sometime after 2019 (God willing and the creek don't rise) some LEO channels may go digital after the first touch and infrastructure changes (and after Mexico clears spectrum).
- FD that is analog now will probably stay analog
I'm asking all of this because I have BC898T (trunking, analog only) that I am struggling to get to work on the San Diego RCS. I have upgraded the firmware to accommodate the rebanding but am still not getting it to map the trunks correctly (I suspect pilot error rather than equipment malfunction).
You are correct that the RCS is in the process (not middle) of a system-wide re-banding.
You are incorrect that the RCS is "still analog". Since day one of the RCS, it has been a mixed mode system with most law enforcement agencies operating in ASTRO digital mode, and fire departments, local governments, etc. operating in digital.
There is an effort to convert everyone to digital so that when the NextGen RCS hits the street, folks are used to operating in a digital environment, and their subscriber equipment is equipped with the necessary feature set to operate on it.
You may be thinking of the San Diego City 800MHz system in which most (but not all) traffic (including law enforcement) is still analog.
K6CDO can vouch that I speak with authority on these matters.
Indeed, d119 is correct on the above. However, there are things underway that he does not know about. :wink:
Don
Thank you Don and d119 for your quick replies.
Given that my main interest is monitoring, Calfire, Escondido and San Diego FD and I have a BC898T which is a capable analog trunking scanner and supports rebranding... in your opinion is it time to start making the case to my wife that I "need" a new digital scanner:
