San Francisco Radio
clawhammer
West Central Florida
Hey everyone hope someone can help me out on this on. I live in the Tampa bay area and while I listen to a lot of aircraft monitoring I have be listening to San Francisco radio on 131.175 for many years and it has always been hard to listen to the ground dispatch side. but 2 days ago that all changed, they are now crystal clear up my way. what I was wanting to know it they have moved there transmitter site I tried to find info on san francisco radio but had no luck can anyone help me out on locating info on this.
Thank you
DickH
Thank you
You must have an amazing radio if you're picking up San Francisco from Tampa Bay, Florida. :)
clawhammer
Hi Dick, just wanted to let you know that the radio I'm using is a radio shack pro-2045 and the antenna I'm using is a grove scanner beam and have it pointed directly at Tampa International, I have no problem listening all the approach and departure and tower frequencies. my concern is with San Francisco radio there are 3 repeater sites if that what you want to call them. one is at MIA Int, TIA int, and JAX int. from what I was told on how it works is when an airline is in range they dial the number to San Francisco an it transmits on 131.175 and it broadcasted on that frequency and is relayed via landline to San Francisco and it is used for phone patch and is used to pass information to there company. hope this makes sense. what I'm trying to find out is where the transmitter site is located and what height it's at and how much power there using I just can't seem to find that information, only thing I could find was the frequencies at TIA and the different company frequencies.
Allen: KJ4RZY
DickH
Hi Dick, just wanted to let you know that the radio I'm using is a radio shack pro-2045 and the antenna I'm using is a grove scanner beam and have it pointed directly at Tampa International, I have no problem listening all the approach and departure and tower frequencies. my concern is with San Francisco radio there are 3 repeater sites if that what you want to call them. one is at MIA Int, TIA int, and JAX int. from what I was told on how it works is when an airline is in range they dial the number to San Francisco an it transmits on 131.175 and it broadcasted on that frequency and is relayed via landline to San Francisco and it is used for phone patch and is used to pass information to there company. hope this makes sense. what I'm trying to find out is where the transmitter site is located and what height it's at and how much power there using I just can't seem to find that information, only thing I could find was the frequencies at TIA and the different company frequencies. Allen: KJ4RZY
Are you talking about San Francisco, CALIFORNIA? If so, it is not possible to hear 131.175 in Tampa, FLORIDA from there.
datainmotion
Hoi Polloi
Colorado
ARINC San Francisco Radio
Allen,
If you don't already have it, here is the ARINC Domestic VHF coverage map:
ARINC VHF Radio
It's showing Tampa, Jacksonville, Miami and Pensacola as TX sites for 131.170 MHz
abbydabby
port richey fla
here in port richey i get san fran radio of course the plane is much clearer but i can recieve both sides cause i believe the san fran trans is coming from tia i just wish some one could put a clear broadcast of tia on the net.
clawhammer
I want to thank datainmotion & nd5y for all your help this really helps out a lot, I see that I'm only 28 miles from the transmit site and wow since I raised my antenna height to 60 feet now everything comes in clear now. again thank you everyone for all your help.
Allen: KJ4RZY
All of ARINC's base stations have FCC licenses. You can look them up on radioreference or the FCC web site.
FCC Callsign KIR2 Details
