San Luis Obispo - LTR System 1-xx-xxx
MtnBiker2005
San Diego County, California
FCC: WPGS207 - SCHMITZ, GABRIELE
LTR: 1-xx-xxx
463.2000 - LCN 07
463.6250 - LCN 11
464.1250 - LCN 19
464.6000 - LCN 03
Users:
1-03-031 = BUS (route 1, etc)
KJ6HCB
San Luis Obispo, CA
So, forgive my ignorance, but since this is local to me I figure I should learn more. Ive always just monitored analog standard transmissions - what is involved in monitoring an LTR system? I know you have Control Channels, thats the LCNs above I believe. What else do I need to know, and how do I go about monitoring this setup?
inigo88
California DB Admin
San Diego, CA
LTR can be monitored in conventional mode, the only downside is your scanner won't display the talkgroup so you won't know who's talking. There is no control channel, because all the trunking data is subaudible (kind of like a CTCSS tone). Most systems have most of the talkgroups default to a home channel (aka home repeater). For instance the RTA bus talkgroup on this system has home channel #03, so you should be most likely to hear RTA buses on 464.60 (LCN 03). Then if another radio on a different talkgroup keys up (whose home repeater is also LCN 03) the system will say "LCN 03 is busy, Goto LCN x instead" and they will show up on another frequency.
To program LTR on a Uniden, basically just set the trunking system type correctly and program the frequencies in LCN order (so the LCN 03 frequency goes in the Ch 03 frequency slot). Do a forum search, see the LTR forum, the Uniden forum and the LTR system wiki page for more info.
inigo88
California DB Admin
San Diego, CA
No one spoke up so I've deleted the old system. Here are the old "Communications Enterprises" talkgroups, for reference:
Code:
0-01-002 	A 	SLO Tran Bus 	SLO Transit Bus Operations  	Transportation
0-01-003 	A 	SLO TranData 	SLO Transit Data  	Data
0-01-015 	A 	Paratra01015 	Paratransit  	Transportation
0-01-017 	A 	RTA Bus No 	RTA Bus Operations (North County, formerly CCTA)  	Transportation
0-05-015 	A 	RTA SoCoSupv 	RTA South County Supervisor  	Transportation
0-05-016 	A 	RTA Bus So 	RTA Bus Operations (South County, formerly SCTA)
MtnBiker2005
[Rather than forget this info I thought I'd stick it in this group for future
recovery: for reprogramming the HomePatrol / Scanners.
[Date Logged: March 29th & 30th, 2012]
464.6000 LTR 1-03-
LCN=03, Area=1, Free=07, Idle
LCN=03, Area=1, Free=11, Idle
LCN=03, Area=1, Free=15, Idle
463.2000 LTR 1-07-
LCN=07, Area=1, Free=15, Idle
LCN=07, Area=1, Free=11, Idle
463.6250 LTR 1-11-
LCN=11, Area=1, Free=03, Idle
LCN=11, Area=1, Free=07, Idle
LCN=11, Area=1, Free=15, Idle
464.1250 LTR 1-19- (No voice traffic heard)
LCN=19, Area=1, Free=00, Idle
LCN 15 - frequency ? ? ? ? ? ? ?
LTRLogger files available for download.
MtnBiker2005
[Additional notes for future recovery:]
1-07-044 - Giving Rides / Henry Wood?
1-07-048 -
1-07-101 - Trash Truck/Spanish Speakers
1-07-121 - RUNABOUT - Regional Transit Authority - ADA Paratransit Service
1-07-123 - SLORTA - Regional Transit Authority - Main
1-11-017 - Spanish Speakers
1-11-020 - Spanish Speakers
1-11-022 - Spanish Speakers
1-11-026 - Trash Truck
1-11-027 - Trash Truck (Large Roll-off boxes),(Dropping off at Cal Poly)
1-11-084 - Tow Truck
1-11-095 - Tow Truck (Dispatcher only talkgroup) (Pismo Beach area)
1-11-102 - Tow Truck (Driver only Talkgroup)
1-11-107 - Tow Truck
1-11-109 - Tow Truck (Driver only Talkgroup)
1-11-111 - Tow Truck (Dispatcher & Drivers),(Cuesta College / Costco areas)
1-11-113 - Tow Truck
1-11-116 - Tow Truck (Answering Service talkgroup for the Towing company)
1-11-134 - Tow Truck (Driver only Talkgroup)
1-11-135 - Tow Truck (Tow Away/Private Property Impound(PPI) - Main channel for PPI's?
[College Towing - Provides AAA Roadside Service, SLO Police Towing, PPI]
MtnBiker2005
[No major changes for Location2 - SLO]
Just notice two new talkgroups:
1-11-105 - Tow Truck (talking with user on 1-11-135)
1-11-128 - Tow Truck (talking with user on 1-11-095 , 1-11-102)
____________________________________________________
[System notes for Location1 - ARROYO GRANDE]
464.4500 LTR LCN 0-03
LCN=03, Free=07, Talkgroup 0-03-155 Transmitting on LCN 03
LCN=03, Free=11, Talkgroup 0-03-155 Transmitting on LCN 03
LCN=03, Free=15, Talkgroup 0-03-155 Transmitting on LCN 03
LCN=03, Free=19, Talkgroup 0-03-155 Transmitting on LCN 03
LCN=03, Free=03, Talkgroup 0-03-155 End of Transmission
463.2750 LTR LCN 0-11
LCN=11, Free=03, Talkgroup 0-11-109 Transmitting on LCN 11
LCN=11, Free=07, Talkgroup 0-11-109 Transmitting on LCN 11
LCN=11, Free=15, Talkgroup 0-11-109 Transmitting on LCN 11
LCN=11, Free=19, Talkgroup 0-11-109 Transmitting on LCN 11
LCN=11, Free=11, Talkgroup 0-11-109 End of Transmission
LCN=11, Free=03, Talkgroup 0-11-107 Transmitting on LCN 11
LCN=11, Free=07, Talkgroup 0-11-107 Transmitting on LCN 11
LCN=11, Free=15, Talkgroup 0-11-107 Transmitting on LCN 11
LCN=11, Free=19, Talkgroup 0-11-107 Transmitting on LCN 11
LCN=11, Free=11, Talkgroup 0-11-107 End of Transmission
__________
Extra Notes:
463.5000 Heard MotoTRBO Audio
LTRLogger files available for download from Location1 .
