sangean 909
trap5858
Doylestown PA
#2
Radio shack sells a multi-voltage adapter that has 4 different plugs. I do not know the model number but had one when I had my 909.
Kingman, AZ
#3
Yeah you can get tons of cheap chinese wall warts from all over for it like there
https://www.amazon.com/T-Power-Sang...1-fkmr1&keywords=sangean+ats-909+power+supply
https://www.amazon.com/UpBright®-Ad...2-fkmr1&keywords=sangean+ats-909+power+supply
Though they tend to introduce noise even on the FM bands a little, the only exception (at least from what I've tried) is if you get a connector adapter and plug a coaxial cable connected to an outdoor antenna into the 3.5mm antenna jack, than it doesn't pick up the noise.
Otherwise rechargeable batteries are a good way to go and the Eneloops (especially the Pro Version) last a nice while.
