joesheets
I would like to do a scan of NXDN freqs. How would I set that up in DSDPlus? Would I set it up in FMP24?
I don't have that file in my DSD folder. Where can I get it?If you open a file called DSDPlus.SCANLIST, it will tell you how to enter the information into that file. Once you have populated the info in the proper format, you hit "S" in FMPx window and the program scans the channels you have entered.
Utilize the Help and Notes files for more info
chris
It isn't a batch file but is a text file with SCANLIST as the extension.
If you open your NOTES file, do a search for ScanList, it jumps to options for FMP24 v2.11. There is a section called New FMP24.scanlist options. Those are the options that are in the provided ScanList file (commented out with a ";" at the beginning of each line)
chris
