ScanerCast Disconnecting
For some odd reason ScannerCast keeps on disconnecting after about 5-10minutes of broadcasting. My internet connection is ok, Scanner is ok, I reinstalled ScannerCast and it still keeps on doing it.
Any ideas???
Thank you
Lucas
PeterGV
K1PGV, ScannerCast author
Mont Vernon, NH
If you're still having this problem, you should post the contents of ScannerCast.log and scannercast_ERROR.log. That'll at least tell us more about the cause of the problem.
Peter
K1PGV
