Scanner Antenna, Omni-Directional Outside, Inside,
digitalanalog
United States of America
Has anyone bought one of these.
http://cgi.ebay.com/Scanner-Antenna...yZ149988QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I tried asking for certain details about this antenna, and the seller became very aggravated with me. ( this is the second seller from eBay that got offensive when asked about certain details on an antenna)
Just wondering if anyone has tried this antenna?
If this antenna/seller has already been discussed, i am sorry, but i did not see anything on it.
brandon
SoCal
If the seller became aggravated with you for asking questions I would steer clear of it!
fineshot1
NJ USA (Republic of NJ)
Thats not a single antenna. Those are 2 three element directional yagi's bolted to a mast perhaps phased together via a harness which looking at the pic I cannot tell for sure there is a harness tying them both together.
freqs
warren michigan
also i think i looked at that one you only get one of those not both but it shows two on the ebay pix i mite be wrong
hoser147
Grand Lake St. Marys Ohio
fineshot1 said:
Thats not a single antenna. Those are 2 three element directional yagi's bolted to a mast perhaps phased together via a harness which looking at the pic I cannot tell for sure there is a harness tying them both together.[/QUOTE
Same thing he pulled with me, Its 2 yagi's that he is representing as one antenna. It was a no sale, I ask.
kb9hgi
IL
It don't say Yagi it says Scanner Antenna, Omni-Directional
Imagin that!
jon_k
Fort Worth, Republic of Texas
Yagi's are not OMNI directional. They are the exact OPPOSITE. He's is either outright being dishonest or doesn't know what he's selling.
The seller says this only comes with 1 of these, unlike 2 pictured. (If there were two and they were coupled, it would be BI-DIRECTIONAL.)
I also find the reception advertised suspect. 30mhz-960mhz continuous coverage? The design of Yagi's are designed to cover a single center frequency. This is defined by the length and space of those elements on the beam. It works very well on its designed center-frequency and anything deviating above/below will just get worse and worse reception.If you change the spacing of the elements, you change the center frequency.
There are multiband yagi's, but the most I have ever seen is for 2 bands. The yagi in that auction looks exactly like a Yagi for a single band only.
He should have gone all the way and advertised coverage from 1mhz-10ghz.
