Scanner Cast crashing
gmclam
Fair Oaks, CA
#2
ScannerCast woes
Can you tell us more about what it does when it crashes? Does an error message display? If so, what? Do you have to restart ScannerCast? Are you using the computer just to stream, or is it doing other things? What version of .net framework do you have installed?
