Scanner Cast - NO SOUND - HELP!
fishinspot
I recieved the email about upgrading my feed to scanner cast. Did exactly what it said to do, logged in on scannercast, it picked up my settings and it appears to be running but I can hear no feed at all. I checked all my wires and the feed is working but I try to listen to it on my feed through on here and I dont hear anything. Any suggestions please???
Thanks,
Doug
w5nra
Portland, OR
ScannerCast error or IceCast error
Thanks,
Doug
I got that too and mine is giving an error saying that it is not connecting to the IceCast server. ScannerCast seems to have 2 different versions of the software with the same version numbers. I tried both versions and they can't connect to the Icecast Server
I have attached the error that I am getting.
kendrik578
Live Audio Administrator
Greensboro, NC
The reason for that is your feed had been down for 2 weeks straight so the system set it to "inactive". Submit a feed change asking us to have your feed set back to active and it should be fine.
kendrik578
Greensboro, NC
Did you make sure you chose the soundcard on scannercast? Also are u using line in or mic? Make sure that what ever your using that you have chose the right sound recording in the computers sound devices.
Taking a listen to it im not hearing anything.
kendrik578
Greensboro, NC
w5nra,
Took care of the description change, however you didn't request your feed back to active:) but i took care of that also.
fishinspot
Kendrik,
There are only three choices, 1 is my microphone, 1 is my web camera, and the other is SigmaTel Audio (2). I chose the last one.
I do not see the line in or mic settings in scanner cast like we had before in oddcast.
kendrik578
Greensboro, NC
Kendrik,
Im going to email you. Check your email.
fishinspot
under the status page it says:
Scanner connection: (audio only selected- no tgs or communication with scanner)
RR connection: SENDING OK to server 'audio3.radioreference.com'mount point '/393902390'
Is this what it is supposed to say?
