Just upgraded my HP-1 with the extreme upgrade. Prior to this, the HP-1 worked fine, no issues. My local police upgraded their system and I could no longer hear them. So, I upgraded the firmware and DB to get up to date.
That, however, seems to be a problem. Now the scanner does not hear ANYTHING. I've tried every trick in the book and suggestions from several postings on this forum. Nothing helps.
I've upgraded to 2.05.03 firmware; 2/2015 DB, and I've checked the squelch, volume, attenuation, services, and several other items, including the antenna connection - although it was working just fine before the upgrade.
I know several posts have had similar problems, but not quite the exact same problem that I'm having. If anyone out there has a suggestion or three, please pass your experience along. If I cannot get this excellent scanner back on-line, I will have no other choice but, to send it to UNIDEN for repair.
Thanks in Advance; :-(
