scanner help!
firebuffchris
I have purchased a bearcat 246 last year. Ive had no problems with it until now. It seems that it wont pick up on certian channels. For example, i could be listening to one trunk id on my 246, and also be listeing to that same id on another radio. The one radio will pick up the transmission, but the bearcat wont. I dont know if its programed wrong, needs a new antena, or whatever. Help is much appreciated. Thanks!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Please do not post the same message more than once - it's considered bad form here. 'Nuff said.
Before anyone can diagnose the issue, a few questions must be answered;
a. Where are you (city/county will do)?
b. To what system are you listening?
c. What is this other radio/antenna are you using that you can hear the transmission that the 246 misses? It might well be an antenna issue, or an issue where the antenna is too much for the 246
d. What did you use to program both radios, or did you do it by hand? Did you use software? Which package, if so?
73s Mike
Gary335
Dundalk
You mgiht try also posting this in the Uniden Scanners board. You might have better luck getting an answer over there, as that board is for the purpose of discussing Uniden scanners. I'm not saying you won't get help here, but there may be some folks over there who might also know something about your problem.
firebuffchris
yes-i had a bit trouble off posting-hit the button too many times-i apoligize.
i am in baltimore county
listening to the 800's
i am also using a radio shack handheld with dual trunking
i am using the antenna that came with the radio (for both uniden and radio shack)
i programmed it by hand using the database on this website
-gary335-ill try posting it there as well-thanks
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Hmm - the RS handheld you are using is likely to be anything from the PRO-92 to the PRO-95....
Anyway, programming the 246 is a totally different animal than programming the PRO series. You must not think of banks, but groups and systems. It is possible that the programming is off - there is a better online manual called the 'Easier to Read BC246T Manual' which can be found in the BC246 wiki page under 'Related Pages' at:
http://wiki.radioreference.com/index.php/BC246T
The other possibility is one I've had some experience with, having worked on several parades in the Towson area. If that's the general area where you are, it's well known to have several holes there that are not-so-kindly referred to by hams as a 'RF Hell' - and with good reason. There are so many transmitters - pagers, taxis, business, ect. - in that area that a condition called 'desense' can be a real headache. It's entirely possible that the RS handheld you are using is resisting this better than the more sensitive Uniden.
Basically put, it means that the receiver is so swamped with received signals, that it locks onto one you don't want to hear (say, a pager) - even if you're not actually tuned to it - and reduces the sensitivity on everything else. Apart from filtering, a different antenna may be necessary. For example, many folks have had excellant success with a 800 mhz duckie from RS - but even that may be too much in such an environment. The classic test - turn on the attenuator when listening to the county. If reception is either unaffected or improves - even slightly - that's a clear sign that you are experiencing desense.
Let's try to tackle the programming angle first, since that's the cheapest way to go. I don't have a 246, but I'm willing to bet there are a few folks in the area that do.
73s Mike
hankv
This leaves us with a number of questions: :D
Where do you live?
Who are you trying to scan (which system)?
Which Talk Group?
firebuffchris
ok-
im scanning in perry hall
trying to scan the 800's
and its a lot of tgs-not just one
I changed the antenna to one you would stick on the roof of a car-and it has improved some but is still missing out.
