scanner install
scannerman200
North Central Alabama
I have a pro-433 scanner installed in my car right above the hump under my radio. The scanner hangs down and when I'm driving, the radio shakes. Is there anything that could make the shake and vibrate stop?
scannerman200
Sorry, I don't have any pics. I have the scanner mounting brackett attached upside down and the radio hangs down. there is a small space between the top of the radio and where the screws are mounted.
ScanDaBands
Banned
State Line
scannerman200 said:
Any suggestions on what I could wedge in that space?
I really am not sure , it's like the others were saying pictures would clear this up a bit.
Maybe a block of wood ? Or is the scanner tilted one way or the other , I've never mounted any kind of radio equipment that way , always in dash or in a console.....well actually I have under dash mounted them - they sure didn't shake though.
ScanDaBands
Banned
State Line
scannerman200 said:
Well, I have a space under my am/fm radio, but my scanner will not fit into it.
I totally understand - been there myself. If you could find one that would I'm sure it would be better for you..........I've seen cases where people have mounted cb's like what you did and they "fill the hole" underneath with something like a meter (swr,power) just to make it "look good"
52to12
south eastern NC/Dutchess Co.NY
Go to your local hardware store or home improvement store and pick up some spacers. Spacers are tublar and vary in length and daimeter. I have had sucess in the past with the spacers filling the gap between the underside of the dashboard and the mounting bracket.
Hope this helps you!
stiffnecked
Foam rubber, buy it at wal-mart in the craft section. Shove that in the space and it will absorb all the vibrations.
