scanner install
scannerman200
North Central Alabama
I have a pro-433 installed in my 2002 ford taurus. I have the radio mounted under the cigarette lighter tray. The scanner is hard wired to the fuse box inside the car. When I turn my fan or air conditioner on, there is a scratchy sound in the frequency coming in. I have checked the antenna connection and that seemed to help a little, but now the issue is back. Any suggestions?
cooldude546
Upstate NY
probably has to do with where your power comes from try just running it off the battery and turning the fan on see if it still makes the sound. Also try to make sure your antenna wires are away from power wires
hope that helps
